Series I, II, IIa, III Land Rovers For all Series Land Rovers
Series 3 Slow crank
Old Dec 4, 2023 | 04:11 PM
Ebuckingham's Avatar
Default Series 3 Slow crank
So we have a series three that sat for two years but started up extremely easily and drove (sort of). We swapped an electronic ignition for the points and fitted a new ignition coil (which works as it creates a nice spark with spark plug out) however now when we try to start the engine turns no where near fast enough to start the car and has a wierd rhythm. It’s not the battery as we tried to jump start of a car and pack and both made no difference. Engine turns nicely with all plugs out. To fit the electronic ignition we disconnected and removed the battery so that might have something to do with it, but it doesn’t seem to be earthing because we haven’t touched any of that and it used to start fine. Any ideas ?
Old Dec 4, 2023 | 05:10 PM
Harvlr's Avatar
My first thought is that the ignition timing got out of adjustment with the work done.
Old Dec 4, 2023 | 05:50 PM
We did think of this but surely this wouldn’t affect it so much that the car barely turns over?
Old Dec 4, 2023 | 06:31 PM
Harvlr's Avatar
It can if the timing is far enough advanced that the cylinder firing works against the starter. I’m not saying that this is your issue. It’s the first thing I’d check.
Old Dec 30, 2023 | 12:14 PM
jimrr's Avatar
3rd Gear
agree, set timing back. I'm not one to believe in coincidences much but you also may have a voltage drop on cranking (a voltage leak somewhere) usually indicated by something getting warm!!, or the starter gave up if it was used much?
Old Apr 16, 2024 | 09:16 AM
hairball29's Avatar
Try connecting the juice to the starter motor directly to see if it cranks at normal speed (please be extra careful it's out of gear)
This happened to me on a Series2A, and turned out to be a dodgy starter relay.
Old Apr 17, 2024 | 09:49 AM
jimrr's Avatar
3rd Gear
I'd say the ideas above should of revealed the malady, any new results?
tnerb33
Sep 18, 2016 07:14 PM
scootch61
Aug 25, 2013 02:16 PM
MCKEAG
Other
Jun 19, 2013 12:49 AM
Captian Adrianus
Sep 8, 2012 08:45 PM
Schloesser
Apr 17, 2011 02:12 PM
