Series I, II, IIa, III Land Rovers For all Series Land Rovers
What is the best way to bleed a clutch on series 3?
Old Jan 10, 2024 | 11:57 AM
mcmorineg's Avatar
6th Gear
Default What is the best way to bleed a clutch on series 3?
I am having trouble with the clutch on my series 3, I thought that I had correctly bled the clutch but perhaps not.
Please correct me if I am wrong:
  • Glass coffee jar on the floor with one end of the hose submerged in brake fluid and the other end attached to the nipple of the slave cylinder.
  • With the nipple backed off 1/4 turn, I fill the reservoir at the master cylinder and tighten the lid.
  • Pump the clutch peddle until almost at the floor, hold it there for 2 seconds and allow peddle to return to the top before repeating the process three times.
  • On the third push of the peddle I hold it down until the bleed nipple is tightened up.
Once again, I thank you in advance!
Old Jan 11, 2024 | 12:31 PM
XXL's Avatar
XXL
There are lots of methods, but 'three' pumps is not a magic number. The number of cycles is how ever many it takes to get all of the air out.
I use this unit from Motive for doing brakes and clutches on most vehicles. It allows for one person bleeding with minimal hassle. I use the 'glass jar' dry to catch waste.
Toran
Nov 19, 2023 09:51 AM
archaeology_student
May 26, 2022 02:21 PM
Ankeneering
Apr 13, 2017 09:39 AM
Lamar Latrell
Jan 17, 2016 01:37 AM
tornado_735
Jan 31, 2011 10:12 PM
