#3673
#3674
#3676
I scored a 2002 P38 150Amp Alternator today from a junk yard for 25.00 with no core charge. Slapped it into my 99 D2 and although my stock alternator was working fine I wanted the extra 20amp for when I add more lights, and eventually a winch.
As soon as I get my Tax Refund I'm either going to try and locate a cheap 04 D2, or buy myself some new 255/70R18 BFG KO2's or Goodyear Duratrac's, a replacement front/rear metal bumper, and a winch.
Paracord wrapped steering wheel is starting to get a lot of attention. Pretty much all my friends love it, and the surplus store I bought the paracord at was like oh wow never heard of that before, but they had to come outside and check it out.
#3677
I didn't know that the p38 got a higher amp alternator. Interesting. Was that on all p38s?
#3679
Received 1,191 Likes
on
Welded the window regulator/guide tabs back on the windows lower rail, spot welds had rusted off. Now, the window goes up and down by the switch. Makes smoking a cigar much, much easier...especially, since the ash tray is a joke on these vehicles.
Also , added a heater resistor to the SAI motor connection. I'd removed the SAI system, motor and exhaust tubing, and ended up with a code. So, hooked up the resistor to fool the computer, to simulate a similar amount of resistance as the SAI electric motor, running. So far, so good. Day four without any CEL.
JINX...knew l shouldn't have said anything about the resistor...Check Engine Light reared its ugly head on the way home...so heater resistor attempt for SAI didn't do the trick.
