A/C blower stopped working, Resistor or Motor?
Old 07-20-2017, 05:06 PM
Mskembo's Avatar
Default A/C blower stopped working, Resistor or Motor?
I know they are both parts that need to be replaced eventually, but I really don't want to do them both right now. Also I've seen the Four Seasons blower motor pretty cheap, but it's a different plug, which is annoying.
Old 07-20-2017, 06:12 PM
LR03NJ's Avatar
Were you able to confirm its dead? Did you try connecting directly to battery? Most likely, connection is loose.
Old 07-20-2017, 06:16 PM
Mskembo's Avatar
That's what I thought, I've been wiggling that connection for weeks and now it's not coming back on when I wiggle it. I guess taking it out and putting it straight to the battery is my next troubleshooting test.
Old 07-20-2017, 06:36 PM
LR03NJ's Avatar
the wire is toast
Old 07-20-2017, 07:17 PM
Mskembo's Avatar
Originally Posted by LR03NJ
the wire is toast
Do you mean the connection or the whole wire? I'm asking how screwed I am.
Old 07-20-2017, 07:26 PM
LR03NJ's Avatar
No, its just the connector underneath the passenger side footwell. Its the thickest wire that gets really hot when connection is loose. Youll work it out. Good luck.
Old 07-20-2017, 07:29 PM
Mskembo's Avatar
That makes complete sense. Thanks, I'll pull it out and play with it this weekend.
acg (08-05-2017)
Old 07-20-2017, 07:55 PM
You should check the wiring diagrams. It could be that no power is coming from the interior fuse box.
Old 08-05-2017, 10:21 AM
acg's Avatar
acg
acg is offline
I am chasing after a similar issue. Did you find out anything new about your issue?
Old 08-05-2017, 12:17 PM
Mskembo's Avatar
i replaced the motor (message Abran and see if he has a used one), and in the process found that a short had happened at the connector and melted it! Was having a hard time getting the motor out and noticed the plastic was a bit melted. So I cut it off and wired in the new connector Abran sent with the motor.
Melted connector next to new connector!
Quick Reply: A/C blower stopped working, Resistor or Motor?
