So what did you do to your Disco today?
#4041
#4042
Water got up right under the head lamps. Next day it kept back firing then would start up but once I put it in drive it would die down. After a while of idle it was fine.
mr4x4 (09-19-2017)
#4043
Thats about where I would feel comfortable going. Any higher and you risk issues. Ive seen some put a small tarp over the front grill/hood when fording deep water. This would be only be for short runs of course. It worked well keeping the water out.
#4044
#4045
I picked up my 98 discovery from the dealer today after declining a proposed replacement of three smog parts that was going to total 1400 plus dollars. I only see the check engine light when turning hard left or hard right anyway. When I got home I joined this forum and took a photo of it... does that count?
#4049
#4050
Did you remember to check the fuse? Did you clear the codes using the pin jump? My code reader only showed a couple of codes on ABS when I was having an issue. The pin jump flash showed about 8 more codes that had been stored that needed clearing.
