Manifold to y-pipe gasket leaks
I've replaced, tightened, retighten. Still leaks. The gasket is like two thin pieces of metal crimped together. Is there alternatives or how to fix leak?
Best I can tell all is in good alignment. Very easy to line the pipe up and slips right on the studs. Maybe I need to drop the whole pipe and clean the surface?
yes, clean it and don't tighten one side. Take your time and do patterns on the studs left and right side till it is in place. Then tighten all the way using a pattern
