Lr3 cheap sunroof drain repair
Drivers front went in the last down pour lol
drivers front i made the same fitting as before but i used right stuff and glued on the inside of the body since there is no access outside
to do this side drop the bottom panel and the one under the steering column u need 2 hands to push the new fitting up the hose
im sure the rears will be next
