Suspension sponsored by Arnott Inc. Talk about your suspension within.
'96 4.0 Suspension conversion?
Old Oct 27, 2008 | 03:29 PM
oliveoil's Avatar
8th Gear
Default '96 4.0 Suspension conversion?
Ready to switch from factory lift susupension and just go with reqular shocks/struts. Do I need to buy a kit for this or is it as simple as going to a suspension shop and have the current susupension removed and shocks/struts installed. Thanks.
Old Dec 8, 2008 | 09:02 AM
oliveoil's Avatar
8th Gear
Default RE: '96 4.0 Suspension conversion?
Does anyone know how much this will cost?
Old Dec 24, 2008 | 12:14 AM
ldivine's Avatar
You'll probably need to order the shocks/struts and then take it to a mechanic to have them installed. It just depends on if you mechanic has the correct shocks/struts for your vehicle. If you're talking about the air suspension then no it's not that simple.
Shocks can be fairly cheap to pretty expensive depending on what you want. Some work better and last significantly longer than others... they can be a pretty penny. I'd check out Atlantic British or British Pacific for some options.
Regards
Old Jan 30, 2009 | 08:29 PM
Fivespddisco's Avatar
ORIGINAL: oliveoil
You need to change your spring perches. the air bag bolt onto the axel and the springs will need to sit on the plate bolted to the axel in the same place. If you need the kit or more advice shot me an email
Justin@Lucky8LLc.com
oclee118
Jul 13, 2009 05:56 PM
enrique
Jan 28, 2009 09:18 PM
mtfinchrr
Jan 24, 2009 07:44 PM
G4AKumar
Jan 14, 2009 11:48 AM
bmkraus
Apr 30, 2008 07:27 AM
