Tires What skins are you rollin' around on? Discuss wrapping your rims in here.
Best All-Terrain Tire?
Old Jan 8, 2013 | 03:23 PM
KCRich's Avatar
7th Gear
I have the General Grabber AT2 as well and could not be happier. However, the set in my size (245/70/16 on disco I, no mods) was not rated M+S. Right price, great performance so far, and as quiet as the next AT tire. It's got the tread pattern you want and will handle your moderate off-road. But again, the ones I've looked at are not rated specifically for snow.
Old Jan 9, 2013 | 07:37 PM
REDrum's Avatar
Right now best ATs on the market are Duratracs--hands down. On my second set.
Off road when aired down they run as well as my KM2s. That said I have not tried the new Nokian AT, I'm a big Nokian fan. http://www.nokiantires.com/tyre?id=11952
Old Jan 9, 2013 | 09:36 PM
driver_42's Avatar
Mike, as has been stated 19" is a tougher find. I am pretty sure that neither duratrac or MTR are in 19 in. I will double check that. As far as A/T the MTR has change over the last couple of years, not for the better. Great off road capabilities but doesn't last when put on pavement for long distance. I have a 2" lift on my LR3 and run 275 65 18 in the duratrac.
Old Jan 9, 2013 | 09:56 PM
wheelgarage's Avatar
Are you using the rods only, or with the combination of the lift module?
Do you know if the 275/65/18's will rub on stock?
Old Jan 9, 2013 | 10:28 PM
driver_42's Avatar
I have rods. The tires i have rub just on full lock and mostly I notice in reverse. Would say 275 65 18 would rub hard with stock height.
Old Jan 30, 2014 | 09:51 AM
jerdog53's Avatar
I'm like Mark who started the thread and need proper tires for my 08 LR3 with 18".
There is a decided lack of mud terrain tires small enough for this allowing stock height.
What I have found in the 265/60-18 and 265/65-18 are as such and rather disappointing
BFG AT
Hankook Dynapro A/TM
Toyo Tires Open Country A/T 112S
WildPeak A/T.
Cooper Disco A/T3
Toyo Tires Open Country A/T II
None of which are really meaty enough for my liking.
I know I could go larger something like the 275/60-18 or 275/65-18 such as the and run the J-Rods full time but I'm a little reluctant to do that due to CV joint ware.
Federal Couragia M/T
Maxxis Bighorn MT
Kelly Safari TSR
Dynapro MT
Goodyear Wrangler DuraTrac
Cooper Discoverer Radial STT
Everything else for 18" are much larger 34" and north of there.
Old Feb 6, 2014 | 08:46 AM
jerdog53's Avatar
I do see that Mickey Thompson makes a 265/60-18 in the Baja STZ....
Old Feb 8, 2014 | 05:02 PM
RAJOD's Avatar
Originally Posted by Land Rover 3 Newbie
Greetings All,
I just bought my first 2008 LR3 with 35,000 miles and I'm looking to replace my stock Contenential 255/55/R19 street tire with something that has an aggressive tread pattern. I plan to do some light/moderate off-roading here in Colorado, but my main focus is snow management. It's difficult to find anything in a 19" rim, but does anyone have any ideas?
I'm currently looking at:
BFGoodrich All Terrain T/A KO
Goodyear Wrangler Dura Trac
Goodyear Wrangler MT/R Kevlar
Without any modifications, should I say with the current height/width? or maybe go a size wider or taller?
Thoughts?
Thanks!
Mike
I have a LR3 HSE with 19" with Perrelli zeros. I live in Michigan and took them to a gravel pit called Bundy Hill. Went through rivers, rocks, hill climbs etc. Two people got stuck and they both had 18" tires. Go figure I don't come close to getting stuck with 19" less aggressive tires.
Took them through 20" of heavy snow, again easy no issues.
I am sure there are better tires in 18" and more options but spending 2k on new rims then 1k on tires just to get a little better grip seems excessive if you are not doing 50 percent offroading.
19" will be better on the highway, and in cornering etc.
I would just buy the most aggressive 19" you can find. If you get stuck too much then go to 18". I took mine into some very big hills and really had no issues. If you need more then buy a used 3k dunebuggy that will climb anything.
Old Feb 8, 2014 | 05:34 PM
RAJOD's Avatar
Greetings All,
Thoughts?
Thanks!
Mike
If you go taller it will throw off the speedometer readings. Wider better in sand, thinner better in snow.
Its a heavy truck compared to explorers. So it already has more pressure per square inch on the tires vs similar sized suvs to begin with.
detcord
Tires
13
Apr 1, 2011 05:57 PM
deucedaprodeuca
Nov 2, 2009 09:58 AM
texmanmoore
Apr 2, 2009 07:44 PM
Willie 00D2
Tires
Dec 4, 2007 07:04 PM
Disco2Guy
Nov 25, 2007 09:54 PM
