Tires What skins are you rollin' around on? Discuss wrapping your rims in here.
Largest tire size for DII with no lift
Old May 18, 2012 | 10:17 AM
filmhog's Avatar
Default Largest tire size for DII with no lift
What is the largest size tire (tallest) that I can run on my stock mag wheels on a 2000 disco II. The truck has no lift done.
Thanks
Old May 19, 2012 | 12:28 AM
Rover_Hokie's Avatar
245/75/16 is what I was told, and what I run and they work out great. I think that is a 31" tire. If you want to go wider, you may need some wheel spacers, but not sure that will give you enough clearance. Others can probably provide more information for you in that regard.
Old May 19, 2012 | 08:20 AM
That's it.
Old May 24, 2012 | 10:07 PM
DiscoPhipps78's Avatar
So a 32" tire will rub the fender?
Sam DaCosta
Jun 7, 2014 11:07 AM
JMON
Nov 29, 2009 08:06 AM
911turbo
Sep 14, 2008 10:53 PM
evillama
Feb 7, 2006 02:53 PM
UCFJWH
Jan 9, 2006 12:48 AM
