Tires What skins are you rollin' around on? Discuss wrapping your rims in here.
Will 275/55/20 fit LR4 with no mods?
Old Nov 15, 2016 | 11:48 AM
farwellbooth's Avatar
5th Gear
Default Will 275/55/20 fit LR4 with no mods?
Hello,
I have the stock 255 55 20 size on now and need to get something better for snow, preferably BFG ATs. Anyone try these and know if the 275 rubs when the vehicle is lowered, turning etc.?
Tire calculator comparisons say the 275 will be .9 inches taller and .8 inches wider. Looking in the well well, raised, lowered, turned etc. it looks fairly tight when the vehicle is lowered.
Also, is there a way to change the speedometer error on the vehicle? So my speedo says correct speed with larger tires?
Many thanks
Old Nov 10, 2019 | 06:48 PM
mtaylo32's Avatar
Did you ever find an answer to this? Thanks!
Old Feb 26, 2020 | 11:30 AM
Johnson Rods's Avatar
LR Forum Vendor
Default Tires for LR4
The 275-55-20 without any mods will rub.
For the LR4 if you have to stay with the 20's I suggest 285-50-20 or smaller.
It you can go with 18 inch wheels, then 265-65-18 will fit but it would be better with our 1.5 inch gentlemen lift.
as shown below a 1.5 inch lift with 265-65-18 BFG KO2 tires on a 18 inch Compo wheel.
You can find more info and a tire size chart on our website: Johnsonrods.com
Follow us on Instagram: @johnsonrods
265-65-18 BFG KO2 tires on 18 inch Compomotive wheels and with a 1.5 inch Johnson Rod gentlemen lift
__________________
Please visit our website: https://www.Johnsonrods.com
Visit our vendor section:Johnson Rods Vendor
Old Jul 24, 2020 | 12:23 AM
danicollins's Avatar
Nice setup you've done there. I've checked this thread because I am planning to install new winter tires that I saw at 4WheelOnline.I want to know if I need to do some calibration and adjustment to fit tires similar to that size.
flmtrain
LR4
Oct 22, 2019 09:39 PM
JUHSTin
LR4
Aug 23, 2019 06:18 AM
Davezerg@hotmail.com
LR4
Jul 12, 2016 07:54 AM
ardifan
LR4
May 5, 2016 01:34 PM
dngvt
Tires
Mar 25, 2016 06:35 PM
