Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Brand Reviews > Audio/Visual Electronics
Register Forgot Password?
Old 05-04-2007, 11:45 PM
Junior Member
Default 96 disco electrical problems
Anyone have a wiring diagram for a 96 disco? I can't get the drivers side speakers on. Front or back. I've checked the wires at the speakers and they are connected. I've also tried balance and fade. It's a factory head unit with the factory 6 disc changer.
I also don't have cruise control, fog lights, intermittent wipers or the light behind the clock. Checked all of the fuses and their good. Anyone have any ideas?
I bought door actuators from www.partsexpress.com for $5 each. They work great if your having door lock problems. Just thought I'd throw that out there.
Kyle
Old 05-05-2007, 12:51 AM
Member
Default RE: 96 disco electrical problems
last thing first, the clock has it's own rover specific bulb, it looks like a xmas tree bulb, next , are you sure you don't have a fuse out? this is exactly what happened to me when i put new fog lamps that were rated too high for the fuse. get the rave cd from rover renovations, this will help you a bunch, i like books so I order the haynes manual from atlantic british. hope this helps and good luck rovering. Bill
Old 05-05-2007, 02:05 PM
okdiscoguy's Avatar
Senior Member
You have an amp behind the glove box for the regular speakers. There might be a fuse back there. I think the wipers and fog lights do through the MFU. Got a RAVE CD and it will tell you how to test it. I think you hold the gefrost button in while turning on the truck release it, and hit it again. When you try the inputs (wipers, washers, rear fog lights, etc) it will beep. if you hit it again, it will fun every thing it controls for 2 seconds each. I am just going off memory...
On the cruise, are you sure it isn't just not lighting up and you have a hose leak? I replaced my clock light, and the lights for the cruise switch went out...might check your lines...
__________________
RAVE
Good Oil
2003 Range Rover HSE with 2008 trim
2010 GLK 350 Mercedes
1990 VW Cabriolet - Lake car...
1997 Discovery SD-7 to put the boat in.
Tags
96, electrical, land, problems, rover
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
