alarm keeps going off for no reason
Old Jan 20, 2012 | 07:16 PM
You could disconnect (cut) wire 1, 5, 9, and 16 on plug C225 on the alarm unit. That removes all the doors and hood, alarm would then just be monitoring itself (unless you have motion sensors). Lights would still work inside because MFU still in the circuit. Could be a crazy MFU, it is on back of fuse block and a PITA to get to.
Old Jan 20, 2012 | 08:05 PM
jordamf's Avatar
I dont have the motion sensros. However i do like the central door locks, so would those still work if i were to dig into this pita.
Old Jan 20, 2012 | 08:16 PM
Yep. This takes away input for alarm, but not door activation of locks. The MFU timer is still connected, and it controls the interior laamps.
Old Jan 20, 2012 | 08:27 PM
jordamf's Avatar
im going to look in to this. cause this would solve all my issues and almost any other future alarm issues. There is a catch, so what is it?
Old Jan 20, 2012 | 08:47 PM
Your alarm system will arm, but there is no sensor left to trigger it. Unlike home or business alarm systems, the Rover system does not supervise the individual door switches with an end of line resistor, etc. Just an open circuit to ground, short when open the door. You could meter these wires to ground with an ohm meter turned up on the highest scale, and may find a small short to ground. These can be something like the green corrosion gunk, or a skint wire. And they can be temperature sensitive, causing problems when weather changes.
Old Oct 14, 2016 | 03:32 PM
Betim Duraku's Avatar
Had the issue with the alarm too! Left it parked for a day or two and feared I had to get it towed. Charged it a bit and ripped out the blue microchip thing connected to the alarm under the hood bypassing the alarm system and starting the car! Worth a go before calling a tow truck!
Old Jan 20, 2018 | 04:02 AM
Marc Swanson's Avatar
And if it continues, you can remove each door switch (one screw) and clean gunk off the inside with small wire brush. Mine was green with corrosion. There is also a switch under the hood, if can't clean it , you can disco-nect.
Can you please explain in more detail, that would really help my causeCheersMarc
Old Feb 23, 2018 | 08:48 PM
rickroverover's Avatar
i have found that the hood sensor can look good but still be the cause.. 2 cents worth but happened to me.
Old Mar 1, 2018 | 12:44 PM
klandrover's Avatar
Default Mine too, this is my hood lock
I tried the 1/5 the 1/3 on my 97 Disco SE and nothing works but only have a manual key. My doors and hood can be opened and red light on dash flashes with no alarm sound. Still can't start. The hood pics are after I had it at a local shop. They bent it so badly I am thinking it is the problem. If I buy new lock could that fix my problem? Read the posts nothing works. Thanks guys.
Attached Thumbnails alarm keeps going off for no reason-lock-hood-1.jpg   alarm keeps going off for no reason-lock-hood-2.jpg   alarm keeps going off for no reason-lock-hood-3.jpg
Marnold-98-Disco
Mar 15, 2023 03:32 PM
Tercan
Jun 20, 2017 08:43 PM
nelbra
Sep 23, 2009 10:55 AM
chiasurf
Jan 31, 2009 04:28 PM
dkeach
Feb 21, 2008 09:30 AM
