very loud exhaust noise from under hood
Old May 18, 2012 | 11:33 PM
Danny Lee 97 Disco's Avatar
Exhaust temps are only about _______ degrees.
Fill in the blank.
Old May 19, 2012 | 09:12 AM
If you have a later model D1, with four O2 sensors, the ECU supervises for that condition and will throw codes. I just cranked up my D1, let it idle until warmed up, with IR thermometer read 600F at exhaust manifold, 400F at first O2 sensor, and 300F or below on the case of the cat, passenger side. Must be some insulation around the inside of the cat, because internally it is going to be over 1000 degrees. Like 1200 - 1600F.
Usually if running rich will make rotten egg smell, and difference between inlet and outlet side of cat will be higher on the outlet side by 500 degrees, maybe more (unburned fuel entering the cat).
Old May 19, 2012 | 10:49 AM
Devin D.'s Avatar
6th Gear
98 Discovery LSE. I pulled the following codes: P0304, P1314 and P1316.
Old May 19, 2012 | 10:54 AM
Devin D.'s Avatar
6th Gear
How do you check the exhaust temp?
Old May 19, 2012 | 12:10 PM
Sav
What codes would that be?
Old May 19, 2012 | 01:00 PM
See gems manual my signature
aftermath431
Jan 22, 2014 09:19 AM
BMW
Nov 16, 2012 09:29 PM
mj_duell
Oct 30, 2012 05:11 PM
jcostello
Feb 20, 2007 07:18 PM
jcostello
Oct 27, 2006 03:39 PM
