Mass air flow sensor
Old Nov 6, 2011 | 12:01 AM
abrady's Avatar
Default Mass air flow sensor
Has anyone tried an after market sensor? Not a gimmic with promises of unbelievable things, but a true reliable one? If so what where your findings.
Old Nov 6, 2011 | 12:20 AM
Nope, but since a D2 MAF is cheap (about $250 vs $1500 for a D1), what kind of problems are you having?
Old Nov 6, 2011 | 03:24 AM
abrady's Avatar
As of right now, none. I have ben reading up possibly replacing my SVS, and the MA FS seemed to come up. So I wondered if there was a better one to replace it with.
Old Nov 6, 2011 | 05:27 AM
abrady's Avatar
Old Nov 6, 2011 | 08:42 AM
I'd say if it a'int broke don't fix it. The MAF is "supervised" 100% of the time the engine is running, so other than cleaning, they usually work or throw codes.
Old Nov 6, 2011 | 01:35 PM
Why are you into replacing parts, do you have any fault codes, what exactly, by number, are they.
As for your question, if you have read anything regarding MAF's you would know you can't use an after market MAF, not even a Bosch generic, it has to have matching part numbers or it will fail right out of the box.
Old Nov 7, 2011 | 07:37 AM
abrady's Avatar
Nothing wrong yet they I know of. From reading different threads in here it seems like the MAF pops up a bit. Mainly hire gimmicky it can be with certain aftermarket intake systems. So I was just wondering if there was a more robust MAF out there to replace it with. Either when/if mine went out (still using factory airbox) or as a preventative maintenance. That was all.
It can get quite confusing with so many different opinions in separate threads about the same part.
Old Nov 7, 2011 | 08:55 AM
No, there is not, main thing is keep a clean air filter and don't suck in any water.
Old Jan 31, 2012 | 09:58 AM
rimasco's Avatar
Mike.. Im getting a P0102 reading.. I tried cleaning, no luck.. my question to you is.. how do I know which Bosch to go with?? I bought this 2001 D2 SE and it had a "USMotors" MAF in it already?? I seen brand new BOSCH MAF (suggested by site) for D2 for $115?
Old Jan 31, 2012 | 10:06 AM
rimasco's Avatar
says its an OE exact fit for 01 D2.. Mfr #: W0133-1603746 ??
bcolins
Jan 2, 2020 12:07 PM
seamuspg
Mar 1, 2011 10:50 AM
alpheus
Oct 27, 2010 05:29 PM
Gavster
Apr 15, 2009 01:44 PM
Gavster
Apr 10, 2009 02:49 PM
