Clunking Sound After doing TF 2" Lift
Old 12-01-2012, 09:14 PM
CoastieDisco2's Avatar
Default Clunking Sound After doing TF 2" Lift
So 2 weeks ago I put in a 2 inch lift from TF. I watched all videos on how to and read everything needed from RAVE Manual. It went pretty straight forward and my friend and I replaced all parts easily. Now when I drive over any bump.dip..etc significant on the road I have this clunking coming from the suspension. I think it is either front right or rear right. I took off wheels again and checked things but do not notice anything out of the ordinary.
Please help with any suggestions you may have on what to look for. Thanks! Sound was not there prior to for sure.
Old 12-01-2012, 09:40 PM
jafir's Avatar
Did you get the front lower spring seats bolted down tight? On my 3" lift it took some serious man handling to get them to line up with the new springs and shocks in.
Old 12-02-2012, 07:40 AM
jeffh's Avatar
My thoughts are similar to Jafir's. I recently replaced my front springs and had a bear of a time getting them to seat properly. I had to re-do the front right 3 times before I got it settled and could bolt it all down.
Old 12-02-2012, 08:16 AM
coors's Avatar
Maybe your bushes are worn out. And its now showing because the lift has added additional stress. Check the rear bushes for play.
Old 12-02-2012, 09:21 AM
lr2001silver's Avatar
Banned
Have you replaced your drive shaft yet? If not you need to do so soon.
On the noise did the rubber bushings come out on one end of a shock?
Old 12-02-2012, 09:37 AM
ZGPhoto's Avatar
I almost guarantee it's a spring that's not settled correctly. Sometimes you have to find some feature to articulate on and hit the spring in with a rubber mallet.
jycsalas
05-23-2019 03:02 PM
amybc96
09-26-2013 06:42 PM
codialito
09-19-2009 06:08 AM
tobob1
10-03-2006 11:37 AM
MaxColee
06-25-2006 09:49 PM
Quick Reply: Clunking Sound After doing TF 2" Lift
