Sponsored by: CARiD
Strange "clunking" noise
Old Sep 18, 2009 | 12:08 AM
codialito's Avatar
Default Strange "clunking" noise
Hi everyone, Im new, so spare me the flaming and just help if you would be so kind.
Anyway, I have a automatic 97 land rover discovery with 140k miles. The problem is a clunking noise that I have just started to notice. The clunk comes when I go heavy on the throttle, it down shifts for power, then when I let off the gas abruptly it shifts up and it clunks. I dont know if thats exactly what the shifting does in a auto since I am use to manuals.
So my question would be is that the "torque converter" (what one of my friends said)? Or is it something else? More importantly what can i do to fix it. Im fairly mechanically inclined but it is a european car so Im hesitant.
P.S. If I ease the throttle out slowly it does not make the clunking noise.
Old Sep 18, 2009 | 06:15 AM
Have you checked your fluid levels, when was the tranny last serviced, have you inspected and lubed your u-joints, have you checked your motor mounts for cracks?
Old Sep 19, 2009 | 01:35 AM
codialito's Avatar
fluids are all good
still need to check on my service records, purchased the rover used
The sound doesnt come from one side or the other and i can feel it in the throttle so i dont think its the U joints.
I will check the motor mounts tomorrow when the suns out.
Thanks for the advice.
Old Sep 19, 2009 | 06:08 AM
antichrist's Avatar
At 147k there's a good chance that suspension bushings are worn, which will cause clunks. The rear axle A-Arm ball joint also causes clunks when it's really worn.
jtm964
Freelander
Sep 20, 2008 03:01 AM
LandRoverDiscoDos
Jun 16, 2007 02:15 AM
bonedoc
Jun 1, 2007 12:26 PM
trangle23
Nov 20, 2006 12:39 PM
tobob1
Oct 3, 2006 11:37 AM
