Head Gasket Question
Old Jan 23, 2012 | 08:56 AM
01d2Jeff's Avatar
Default Head Gasket Question
I'm leaking coolant out of the back side of the p/s head looks to be precisely between the head and the block. No smoke, but it leaks pretty good. I have to fill the reservoir up once every other day, and I only drive about 20 miles round trip. It's a constant drip while the engine is running and at operating temperature.
I'm assuming it's the head gasket, but I've never seen one blow out where it doesn't leak into the oil or the cylinder. I'm assuming that this is possible, though? are there any other possible solutions?
Old Jan 23, 2012 | 08:59 AM
ratijs100's Avatar
I had the same problem with my car and i did whole head gasket job. It was really leaking from head gasket and also if it is closer to the driver's side, it might be water pump seal. In my case those two were constantly leaking and all the time there were drops under the car and I had to add at least half of the bottle every 3-4 days.
Old Jan 23, 2012 | 09:16 AM
There are many ways a head gasket can fail,
coolant leak to outside of the engine
coolant leak into the crank case
oil leak to the outside of the engine
exhaust leak to the outside of the engine
exhaust leak into the coolant system
Plus any other combination, in other word you don't need to have coolant to have a failed head gasket.
Old Jan 23, 2012 | 09:21 AM
01d2Jeff's Avatar
Thanks, Mike.
Looks like I'm replacing a head gasket!
Good thing I parked it last week then. It's amazing....68k on the clock and a blown head gasket....gotta love discos!
Old Jan 23, 2012 | 09:30 AM
That is about the normal time for them to first fail, along with plug wires and the front drive shaft.
Old Jan 23, 2012 | 06:14 PM
ebg18t's Avatar
It seems that between 70-90k miles everything except the seats needs to be rebuilt or replaced.
Old Jan 23, 2012 | 06:59 PM
here's a pix of the back of head leak
Old Jan 23, 2012 | 08:08 PM
G Reeves's Avatar
My cylinder HG went at 55K
mike111
Jun 2, 2014 08:58 AM
FlyingZebra34
Apr 25, 2013 08:04 AM
dancedisco
Feb 6, 2012 06:34 AM
Tastang
Nov 30, 2007 05:47 PM
jcostello
Nov 2, 2006 10:28 PM
