dash warning lights resetting DISC 1999 series 2
Hello all!
I have three (3) lights on my dash I cant seem to make turn off....ABS, traction control, and downhill with excalmation mark, I dont want to go to the dealership, can any one tell me a way to reset these.
I have disconected the battery, this didnt help, any suggestions would be greatly appreciated.
Thanks
Ralph Duke
Thanks
Ralph Duke
RE: dash warning lights resetting DISC 1999 series 2
Don't disconnect your battery, all you will do by doing that is errase the memnory in your ECU and it will take some time to regain that.
Don't take it to a dealer, they will chage you an arand a leg to repair it.
Send me your tele number and a good time time call and I'll walk you thru what you should do.
Mike
Mike
I had the same symptoms and it was related to, and cured by replacing a bad rear air shock. You might get these undicators to go off temporarily, but to have them go off permanently you have to solve the problem. You can get airsprings from Arnott industries for @189.00 each. I would go ahead and replace both at once. They take about 10 minutes to replace once the tire is off.
The only cue for the 3 amigo's is to have a shop with a test book or an AutoLogic scanner, scan for codes, make the repairs and have the codes errased.
There are a few faults taht will not need repair, more like things you can do to make them go away.
Sorry i didn't see the replys, if anyone still wnts to talk about it, send me your tele number and I will call you tomorrow, Sunday.
Mike
Mike
cipher982
11-09-2019 11:22 AM
euronavdiscs
02-06-2016 03:41 PM
