dash warning lights resetting DISC 1999 series 2
Old Mar 18, 2007 | 02:02 PM
rphotographer's Avatar
Default dash warning lights resetting DISC 1999 series 2
Hello all!
I have three (3) lights on my dash I cant seem to make turn off....ABS, traction control, and downhill with excalmation mark, I dont want to go to the dealership, can any one tell me a way to reset these.
I have disconected the battery, this didnt help, any suggestions would be greatly appreciated.
Thanks
Ralph Duke
Old Mar 18, 2007 | 03:29 PM
Default RE: dash warning lights resetting DISC 1999 series 2
Don't disconnect your battery, all you will do by doing that is errase the memnory in your ECU and it will take some time to regain that.
Don't take it to a dealer, they will chage you an arand a leg to repair it.
Send me your tele number and a good time time call and I'll walk you thru what you should do.
Mike
Old Mar 18, 2007 | 03:40 PM
call me tomorrow at 806-584-3330..im in texas central time...i will be home from 1-4..Thanks!!
is this very involed to do???
Thanks Ralph
Old Mar 18, 2007 | 08:35 PM
mikedemet's Avatar
I had the same symptoms and it was related to, and cured by replacing a bad rear air shock. You might get these undicators to go off temporarily, but to have them go off permanently you have to solve the problem. You can get airsprings from Arnott industries for @189.00 each. I would go ahead and replace both at once. They take about 10 minutes to replace once the tire is off.
Old Mar 31, 2007 | 07:35 PM
El Jefe's Avatar
hey, my sister-in-laws 1999 disco II has the same problem. can ya call me too?
Old Mar 31, 2007 | 09:36 PM
The only cue for the 3 amigo's is to have a shop with a test book or an AutoLogic scanner, scan for codes, make the repairs and have the codes errased.
There are a few faults taht will not need repair, more like things you can do to make them go away.
Sorry i didn't see the replys, if anyone still wnts to talk about it, send me your tele number and I will call you tomorrow, Sunday.
Mike
Old Apr 21, 2007 | 01:22 PM
El Jefe's Avatar
hey could you give me a call bout this problem today? my number is 801-645-7823.
Old Apr 21, 2007 | 01:56 PM
StevenDiscoII's Avatar
Another candidate here. I have had mine on for the last 20,000 miles. I am so used to them by now, that if they are turned off one day, I would miss them.[sm=smiley14.gif]
Old Oct 30, 2012 | 05:11 AM
Kat Russell's Avatar
Default kat
Hi I have the very same issue with my dash lights and am now worried to drive the 4x4, can you please help I have only had the discovery for about 6 weeks and know very little about them yet!
Thanks in advance Katherine.
Old Oct 30, 2012 | 08:35 AM
jafir's Avatar
Kat, keep searching. There are a lot of newer posts than 5 years ago with more info on the 3 amigos. But more than likely you'll need someone to scan the abs codes so you know where to start.
cipher982
Nov 9, 2019 11:22 AM
euronavdiscs
Feb 6, 2016 03:41 PM
crainb45
Apr 14, 2009 05:36 PM
Mpowered
May 15, 2007 08:42 AM
XBlade
Feb 26, 2007 10:49 AM
