ECU Tuning - Who does it?
Old Jan 16, 2012 | 05:24 PM
TripleThreat's Avatar
Default ECU Tuning - Who does it?
Several years ago I ran across a company that was modifying stock ECU's in Disco IIs to improve power and efficiency.
I had their website bookmarked on my computer, but it crashed and had to be rebuilt. Unfortunately, I lost that bookmark...
Anyone have any ideas about who does this?
Old Jan 16, 2012 | 05:42 PM
I have lost track of them, but will look.
What are you hoping to gain by having the ECU rebuilt?
Old Jan 18, 2012 | 11:58 AM
Mike,
If I recall correctly, the advertised benefits were increased fuel economy and better power for towing. I was hoping to follow up to see if these were legitimate gains, or if it was a bunch of hype...
I know that, often times, ECU's are programmed in such a way to meet emissions requirements all along the RPM range and that stock tuning sometimes results in an area where the resulting engine performance is less than optimal in terms of power and torque.
If I remember correctly, the company I am referring to had a variety of different programs that were based on the octane rating of the fuel the owner committed to using.
I use my Disco II to pull an enclosed 7-1/2' x 18' Aluminum trailer with a couple of motorcycles in it back and forth to race tracks across the Midwest and Southeast on occasion. I don't tow regularly and the weight of trailer and contents is under 5000 lbs.
The Disco does a great job for the most part, but the fuel economy is terrible and it can also be a bit squirrelly at highway speeds due to the short wheelbase. The trailer is a dual axle and as long as it is loaded correctly, it's really not a big deal. The short wheelbase is a huge benefit when maneuvering the trailer in the paddock area, especially when backing.
A little more power and a little better fuel economy would make things that much better, so if their claims are true, it might be worth the investment.
Jeff
Old Jan 18, 2012 | 01:19 PM
Here you go. ECU re-do will work, it makes engine behave by new plans, not try to fight and fool them like the basic resistor change. Also not under $100.`
RPi Engineering - V8 Engine - Carburetion and fuel Injection
Old Jan 18, 2012 | 08:40 PM
If your trailer is unstable at highway speeds you are either driving to fast or have it loaded wrong.
The weight needs to be 60/40, 60% in front of the axles and 40% behind them.
To much tongue weight and the truck will be unstable, no enough and the trailer will be unstable.
Old Sep 20, 2012 | 11:21 AM
tracked's Avatar
Default look at
phantom based in manchester but they come to you
www.phantom.uk.net
i had my disco and then a sport chipped best thing ever
Old Sep 20, 2012 | 11:31 AM
That's a long swim across the pond .
Old Sep 20, 2012 | 11:40 AM
ashtray's Avatar
It'd be awesome if there was a good rebuild or chip for DII's. I'd love to have MORE POWER!
Patrick Duffy
Nov 16, 2012 05:17 PM
BrianH
Engine & Internal
May 31, 2011 01:02 AM
andrew65
Off Topic
Jan 28, 2009 09:48 AM
Janeuxn
Sep 1, 2008 12:21 AM
p38spares
May 14, 2007 03:55 PM
