O2 codes after head job
Old 01-18-2012, 08:39 PM
jrm123180's Avatar
Default O2 codes after head job
I just did a complete head job on my D2 because one of the heads was leaking and while they were off I decided to do them right.
I was getting O2 codes prior to this (I posted a number of times before while trying to figure this out).
Now that I have the motor put back together, I'm getting
0134
0135
0154
0155
I had another set of sensors so I put in the bank 1 & 2 sensor 1 to see if that changed and it didn't.
any sugggestions on what these could be or would they possible take a while to go away...I have not driven the car yet, only idled it.
Thanks,
Steve
Old 01-18-2012, 08:48 PM
Wiring or connector problems - these are codes for continuity problems. See attached pages from Bosch manual on the ECU codes and what voltage values trigger them
File Type: pdf
Old 01-18-2012, 09:00 PM
jrm123180's Avatar
Thanks! i'm def saving that. Any suggestions on remedies?
Old 01-18-2012, 09:51 PM
bosshogt's Avatar
Check your front two O2 connectors for green corrosion. Clean them with electric spray and use dielectric grease. Took the dealer over a month to figure that one our on my 2003 2 years ago.
lyleorszulak807
10-17-2010 11:07 PM
baburhan
10-02-2010 03:23 PM
blast20
08-02-2010 09:02 PM
scubaman
12-16-2009 07:41 PM
Quick Reply: O2 codes after head job
