Service Engine Soon light after Transfer Case job
Old Sep 18, 2012 | 09:21 AM
aguison's Avatar
Default Service Engine Soon light after Transfer Case job
I had the following work done on my 03 D2 SE7:
1. Reseal parts of the transfer case and replaced the leaking rear main oil, cross seals and oil pan gasket
2. Replaced leaking thermostat housing and bled cooling system
Unfortunately I had to pick up the car after business hours after paying the mechanic on the phone.
When I started the car, the Service Engine Soon light came on. Except for a noisier sound when the car first idles, the car appears to drive normally.
I connected a scanner and fetched the following from the device:
3 CODES
P0154 SEVERITY UNKNOWN CONTACT SERVICE GROUP 800 228-7667
P0135
P0155
MIL ON
MONITRS
4 INC
CATALYST
EVAP
SEC AIR
02 SNSR
4 READY
MISFIRE
FUEL
COMP
02 HTR
What do these mean? Would these be related in any way to the job that was done?
Many thanks
Al
03 D2 SE7 86K
Old Sep 18, 2012 | 09:37 AM
135 is a heater circuit malfunction bank 1 sensor 1
155, low voltage bank 2 sensor 1
154 , no activity 0n 02 bank 2 sensor 1.
What what he charged you, you should call him this morning and make sure he pays for these repairs, if he wants to retain a good customer or stop your credit card payment till it is resolved.
He should have test driven the vehicle before giving it back to you in this condition.
Old Sep 18, 2012 | 10:16 AM
aguison's Avatar
Hi Mike
The job cost $1400
It sounds like you think his work caused the codes - could u explain?
Old Sep 18, 2012 | 10:35 AM
For some reason both front 02's have failed, good chance he may have caused it, even if he didn't, he should not have allowed that truck out of his shop with the service engine light on, so yes, I would hit him up for it.
kcferna
Jul 7, 2009 08:33 AM
lipadj46
May 20, 2009 05:18 PM
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
Woody Reems
Nov 29, 2005 06:08 PM
rinmud
Oct 1, 2005 04:32 PM
