Rear gate stuck
Does the handle on the outside move freely? If not, use a flat head screw drive and pop up the Land Rover emblem on the handles plastic housing. Yes this seems weird but it works. Then shoot some oil on the pivot points. If this doesn't work pull the inside panel off and you can access the lock and unlock manually to see if the lock is bad.
X2 or maybe it was 3 ;-) the logo actually pops out pretty easy. Wd40 on the pivots will get you going again. Mine used to get stuck all of the time. Glad I got that tip!
speaking of the door stay....I did lube that a few months ago...but when I bought my truck it wasn't attached and the stay was just folded underneath the door. Well I finally figured out there was a arm that should be there and got it lubed and worked out, but the "bolt", "****", whatever it is, that the arm attaches to is rusted out so bad I can't tell what it once was. It's just a rusted post now. Anyone give me a name for this thing so I can replace it?
Mrmerlin
12-14-2010 08:21 PM
