Sea Foam Question
Old 08-06-2007, 08:11 PM
Camdisco24's Avatar
Default Sea Foam Question
I recently figured out that I need to fill my disco with premium gas, I put in a can of sea foam when i changed over. Since I was using regular for a while should I put in another can next time i fill up since there might be alot of carbon build up?? Or would one can be enough for now?
Old 08-07-2007, 07:30 AM
Default RE: Sea Foam Question
How many miles on the engine, how often do you change your oil?
Mike
Old 08-07-2007, 01:04 PM
Camdisco24's Avatar
There is about 92400 (2000 DII) and I change the oil every 5000-6000 (I use the best oil that last for 10000 but i forgot what it was called)
Old 08-07-2007, 04:40 PM
Rondo's Avatar
Hey, if you've got the money put a can in every time. It won't hurt your engine. Some people like to put a little in with every tank to keep things clean. Might want to run a can through your intake plenum (search the forum) to help clean out the gunky build-up you likely have.
Old 08-07-2007, 04:44 PM
And change your oil more frequently if you don't want to have a short lived engine.
It is not the oil quality that is the problem, it is the fact that at 3000 miles your engine has so much fuel and hydrocarbons in i that you will just build up sludge and loose oil pressure.
Mike
bigugly82
03-14-2018 05:09 PM
llPANCHOll
12-31-2008 12:49 PM
DeepBlueWater
10-16-2007 10:23 AM
mowthat
02-14-2007 10:03 PM
mikemeyer0
06-16-2005 04:00 PM
Quick Reply: Sea Foam Question
