Sea Foam Question
I recently figured out that I need to fill my disco with premium gas, I put in a can of sea foam when i changed over. Since I was using regular for a while should I put in another can next time i fill up since there might be alot of carbon build up?? Or would one can be enough for now?
Hey, if you've got the money put a can in every time. It won't hurt your engine. Some people like to put a little in with every tank to keep things clean. Might want to run a can through your intake plenum (search the forum) to help clean out the gunky build-up you likely have.
And change your oil more frequently if you don't want to have a short lived engine.
It is not the oil quality that is the problem, it is the fact that at 3000 miles your engine has so much fuel and hydrocarbons in i that you will just build up sludge and loose oil pressure.
Mike
Mike
