T Case....
Old Nov 8, 2011 | 12:53 AM
kman35ca's Avatar
Default T Case....
Changed my diffs and Tcase fluids today. Diffs where fine but the plug on the T case was full of big metal filings and some chunks of metal. Wondering what my options are. Found an 04 T case on Ebay for $300. has the cdl, just wondering if thats a real pita to install and then would I have to get a kit to install a lever into my interior? Or just go with a rebuild?
Old Nov 8, 2011 | 05:36 AM
Or in the mean time run 85W140 syn gear lube while you evaluate your options. T Case plug is magnetic to keep trash from floating around and reduce damage.
Old Nov 8, 2011 | 09:48 AM
kman35ca's Avatar
Ya good idea. then I'll just keep an eye out for a good replacement T case and hopefully it'll last a while longer. Thanks dude.
Old Nov 8, 2011 | 05:23 PM
threalassmikeg's Avatar
I've not seen a tbox fail under normal conditions in my 20 yrs w land rover
product. they should outlast the truck.. Drive it and don't worry about it.
Old Nov 8, 2011 | 05:26 PM
Not to discredit you, but you haven't been looking in all the right areas, they do fail, even as daily drivers much less when wheeling hard.
Old Nov 8, 2011 | 05:30 PM
And from what Tom says, roll back wreckers can wreck them in less than 15 feet....
Old Nov 8, 2011 | 05:34 PM
No offense taken Mike
The OP stated he changed his fluids. He didn't say he had any problems with
his tbox. No need to panic..
imag
May 12, 2006 07:59 PM
adowgiert
Aug 27, 2005 04:53 PM
garnstar
Aug 3, 2005 01:45 AM
Loose_Screws
Jul 22, 2005 12:13 AM
Smokeyone
Jun 4, 2005 03:11 AM
