Wipers Don't Work, Radio Doesn't Shut Off With Key
Do you have anything plugged into your cigarette lighter port? Mine was doing something similar when I had my cell phone or GPS plugged in, it wouldn't turn on the dome light until I pulled it or waited a minute or so. Almost as if it was giving me mercy power after shutting down the truck.
I'm probably way off, but weirder things have happened.
After that, I removed, cleaned, and rebolted any ground wires I could find.
I just can't think where to begin searching for the issue when this began simply after changing a light bulb.
I hope I'm not insulting anyone, but did you check all your fuses and relays? Both under the steering wheel and under the hood?
If the radio is staying ON though, you probably have a short somewhere in the accessory wire that tells it to turn on/off. Electrical problems like this are the worst. I had a fried wire to my cigarette lighter and it made all sorts of funky things happen. Hopefully you won't have to rip everything apart to check all the wiring...
Hopefully Buzz will chime in... he's seems quite knowledgeable about the electric systems of these trucks.
I have a customers 01 Disco with the same problem, wipers don't work, radio wont turn off when key is turned off and seat heaters don't work. I printed out a wiper wiring diagram and saw that the Auxiliary Circuits Relay was on the page so I swapped the ABS and the Aux relays and everything started working again, so I replaced relay and all is well.
Any guidance will be greatly appreciated!
UPDATE: Been doing research today about this Relay, is it the Ignition auxiliary circuits relay (#7) ? (I have highlighted it in the PDF file; left part of the electrical circuit diagram).
Last edited by macutan; 10-11-2023 at 01:08 PM. Reason: added Electrical Circuit Diagram
