Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Freelander
Register Forgot Password?
Old 11-20-2011, 02:14 AM
Junior Member
Default 02 freelander wiper fuse keeps blowing up?
Hi there. My buddy has a 02 freelander and the wiper fuse keeps blowing up? He said replaced it about 3 times already but it just keeps blowing fuses. I was thinking its a loose ground or something in that area. Does anyone have a wire diagram? Anyone had this problem before? Do you guys think it's the relay or wiper motor? I would appreciate any help. Thanks
Old 11-20-2011, 08:37 AM
Senior Member
probably the motor but disconnect the motor and start using it to see if it blows.
if it doesn't then its the motor. if it does then start down the line.
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
Old 11-20-2011, 02:05 PM
Junior Member
Thanks will try!
Old 11-20-2011, 03:28 PM
Junior Member
Also he said that it kind of works once the car is warmer up??? Weird? Any one knows?
Old 11-20-2011, 03:50 PM
Senior Member
yes if that is the case then take off the steering wheel cover and back probe the wiper switch for power on both sides. if it is working it will close the circuit and you will get power to both sides of the connector.
__________________
Tags
02, 04, blowing, blown, blows, directions, freelander, fuse, fuses, land, landrover, location, range, rover, windshield, wiper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
