Freelander Talk about the Land Rover Freelander within.
02 freelander wiper fuse keeps blowing up?
Old Nov 20, 2011 | 02:14 AM
fullybuilt2.0's Avatar
3rd Gear
Default 02 freelander wiper fuse keeps blowing up?
Hi there. My buddy has a 02 freelander and the wiper fuse keeps blowing up? He said replaced it about 3 times already but it just keeps blowing fuses. I was thinking its a loose ground or something in that area. Does anyone have a wire diagram? Anyone had this problem before? Do you guys think it's the relay or wiper motor? I would appreciate any help. Thanks
Old Nov 20, 2011 | 08:37 AM
Rovin4life's Avatar
probably the motor but disconnect the motor and start using it to see if it blows.
if it doesn't then its the motor. if it does then start down the line.
Old Nov 20, 2011 | 02:05 PM
3rd Gear
Thanks will try!
Old Nov 20, 2011 | 03:28 PM
3rd Gear
Also he said that it kind of works once the car is warmer up??? Weird? Any one knows?
Old Nov 20, 2011 | 03:50 PM
Rovin4life's Avatar
yes if that is the case then take off the steering wheel cover and back probe the wiper switch for power on both sides. if it is working it will close the circuit and you will get power to both sides of the connector.
boris_gti
Oct 29, 2011 12:39 PM
mattrickman
Jul 21, 2011 05:33 PM
bosshogt
Feb 11, 2011 03:28 PM
rayrap
Dec 19, 2010 04:27 PM
sfxgamer
Apr 19, 2009 01:06 AM
