Freelander Talk about the Land Rover Freelander within.
2002 Freelander K6 - Error codes
Old 11-22-2008, 10:08 AM
caysteve's Avatar
3rd Gear
Default 2002 Freelander K6 - Error codes
Hi Guys,
I have a 2002 freelander which is setting the following error codes: P0305 , P1472 and occasionaly P0174. After clearing the codes it will run for a few days before setting them again and then the check engine light will come on for a while, clear itself and come back etc..
I have changed plugs, checked the HT leads, swapped the injectors around (to see if it moves from the Cyl 5 missfire), checked the vacum connections and cleaned all the electrical connections I can reach.. oh and fitted a new Mass flow sensor...
After doing all this it's improved, takes longer to set the codes.. but they still come back.. Anyone have suggestions on what else could be causing this, would the O2 sensors cause it?
Thanks, Steve
2002 Freelander, 2.5l auto, US K6 engine.
Old 11-25-2008, 12:00 AM
tacomatech's Avatar
Default RE: 2002 Freelander K6 - Error codes
Variable Intake Manifold.
Old 11-26-2008, 06:03 PM
caysteve's Avatar
3rd Gear
OK, thanks.. Took the VIM off today and checked it.. Motors and throttle seem ok.. found a broken vacuum pipe during the process, fixed that and put it all back together. Also noticed the female vacuum pipe quick connector on the front head seemed leaky(this is thevacuum pipe that connects the 2 heads and runs under the VIM on thegearbox side of the motor).. think I managed to seal this.. (not sure if this connector can be changed/repaired)..
Anyway ran the car after rebuild and so far check engine light had not come on and no codes set.. I'll run it for a few days and see how it goes..
Old 12-09-2008, 10:58 PM
tacomatech's Avatar
Good find. Connector is able to be exchanged.
Woody426
Freelander
12-02-2013 06:42 AM
BIGTSV
08-12-2013 06:19 PM
pixel
05-13-2011 07:24 PM
ramrod24
12-05-2010 08:32 PM
asterix
10-26-2005 07:23 PM
Quick Reply: 2002 Freelander K6 - Error codes
