actually the blower motor fails because the heater core is leaking.
you will need to pull the dash to fix the heater core, if you don't believe me look at the sticker on the blower motor under the dashboard on the driver side. if its stained pink the heater core is leaking.
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
