Sponsored by: CARiD
Warning lights
Old Dec 9, 2011 | 03:53 AM
cmcswindon@live.co.uk's Avatar
Default Warning lights
Some times when going from drive to reverse in my series 2 auto both the Manual mode light and the Sport mode light flash on the dashboard and its like the car is in crawl mode. These light go out when the engine is turned off and stay off when the engine is re started.
Any help with this would be gratefully recieved.
Old Dec 9, 2011 | 04:13 AM
In the RAVE, workshop manual for D2, automatic gearbox, they have a table of codes (usually in the 700's) that the tranny will send. Attached. It sounds like it is being forced into limp mode.
So does your check engine light come on when starting up (bulb test)? Does it come on when this M & S light does? If so, any codes?
Tranny ECU (yes, it has one just for that) monitors battery volts, M & S can come on just for low battery or dirty terminals. So before tranny repair shop, test battery volts, test fluid level, and a fluid / filter change might also be in order if you have not done one in last few years.
File Type: pdf
Old Dec 9, 2011 | 08:16 PM
If it ONLY does it while shifting from drive to reverse or reverse to drive then it is a faulty XYZ switch, yes, that is the actual name of it.
Switch Gear Position Xyz D2 | Land Rover Electrical Parts, Batteries, Relays, Lamps & More
You can find it cheaper, and some have taken theirs apart and repaired it.
Before buying anything have your battery and alternator tested, if the battery voltage is to low it will do the exact same thing.
Do it do it first thing in the morning or anytime?
cipher982
Nov 9, 2019 11:22 AM
gmutis
Jul 21, 2006 04:43 PM
ptmelendez
May 12, 2006 08:06 PM
ChrisK
Freelander
Dec 19, 2005 01:38 AM
skilley
Dec 12, 2005 09:24 PM
