Sponsored by: CARiD
service engine light
Old Nov 1, 2011 | 04:33 PM
my daughters truck's Avatar
4th Gear
Default service engine light
I need help. My daughters 04 freelander died out 2x. Had it towed did full tune up and was fine. Service engine light went of and ran fine for several days NOW the light is back on and the rpm's shot up even when stopped at a light! I have read horror stories on this truck. Any suggestions. 57000 miles
Old Nov 1, 2011 | 04:51 PM
nahtanoj's Avatar
go to a local autoparts store and borrow their code reader. then let us know what codes it's giving you.
jon
Old Nov 1, 2011 | 05:58 PM
4th Gear
We have a code reader. The service engine soon light is on and no codes show?
Old Nov 1, 2011 | 06:03 PM
4th Gear
Its not a check engine light
Old Nov 1, 2011 | 06:22 PM
The "service engine" soon is a emissions reminder, it is telling you that there is a problem with the emissions system on the truck, either bad O2 sensors or some other emissions device is bad.
It has a BMW engine (assuming you have the I-4 and not the diesel) so any European import shop can work on it for you.
Old Nov 1, 2011 | 06:32 PM
Not sure if your reader picks up the tranmission ECU codes, which can also cause the SES or MIL light to come on.
Also text from the RAVE, in typical dealerspeak:
Malfunction Indicator Lamp (Service Engine Soon)
The MIL illuminates at all times when the ignition is in position II and the engine is not running. If the lamp remains
illuminated or illuminates when the engine is running, a fault has occurred in the engine emission control system or
an emission related automatic gearbox fault has occurred. Stop the vehicle and switch off the ignition for at least 30
seconds. If the lamp illuminates after the engine is restarted, rectification must be sought as soon as possible to avoid
potential engine or gearbox damage and excessive exhaust emissions.
File Type: pdf
Old Nov 1, 2011 | 07:49 PM
4th Gear
Thank you very much! Bringing it in to a friend to have this looked at. Printed all your helpful info for him! Wish we had time to fix it but the husbands too busy with work and my daughter needs her truck!! You are all so wonderful to take the time to help!!
Old Nov 4, 2011 | 08:28 AM
Rovin4life's Avatar
If you get a 1472,71,70 ignore them. If you have a 0171,0174 check for broken pcv hoses. If you get 606,or a code similar to throttle body code then look at getting a new throttlebody connector. it can be purchased at the dealer. there is a bulletin for it.
kcferna
Jul 7, 2009 08:33 AM
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
blackrover
Aug 20, 2007 06:40 PM
97LANDISCOVERY
Aug 19, 2007 04:10 PM
97rover
Apr 13, 2005 02:19 AM
