Sponsored by: DashLynx
Flashing the green S and M lights
Old 06-07-2007, 05:34 PM
Larry's Avatar
3rd Gear
Default Flashing the green S and M lights
My 2003 Disco with 40,000 miles is flashing the green S and M lights and the shift indicatoris flashing. Any ideas of what the problem may be would be great.
Thank you in Advance
Old 06-22-2007, 01:41 AM
wardolb's Avatar
Default RE: Flashing the green S and M lights
get a new battery, or its the position switch monitoring on the trans..take it to advance to check the codes..that should tell you the problem..
Old 06-22-2007, 08:07 AM
When the lights flash green, this indicates that there is an electrical problem with the tranny, if it comes back on after a restart go directly to the dealer to prevent any additional damage, that is right out of the owners manual.
Mike
Old 08-13-2007, 06:26 PM
jazdisco2002's Avatar
7th Gear
yeah check the battery. mine did the same. found out my negative cable had came loose.
Old 08-13-2007, 07:36 PM
If not that, don't drive it other then getting it to the shop.
Do you have an owners manual, if so it would be a good idea to read up on your truck for future issues.
Old 08-22-2007, 02:53 PM
LrTECH's Avatar
sounds like a battery to me
Chrisinhouston
07-01-2020 04:39 AM
Joe Pundzak
02-09-2013 12:49 PM
Jadreigo
09-13-2012 07:25 PM
vishrb
07-07-2010 08:26 PM
Quick Reply: Flashing the green S and M lights
