Sponsored by: CARiD
Flashing the green S and M lights
Old Jun 7, 2007 | 05:34 PM
Larry's Avatar
3rd Gear
Default Flashing the green S and M lights
My 2003 Disco with 40,000 miles is flashing the green S and M lights and the shift indicatoris flashing. Any ideas of what the problem may be would be great.
Thank you in Advance
Old Jun 22, 2007 | 01:41 AM
wardolb's Avatar
Default RE: Flashing the green S and M lights
get a new battery, or its the position switch monitoring on the trans..take it to advance to check the codes..that should tell you the problem..
Old Jun 22, 2007 | 08:07 AM
When the lights flash green, this indicates that there is an electrical problem with the tranny, if it comes back on after a restart go directly to the dealer to prevent any additional damage, that is right out of the owners manual.
Mike
Old Aug 13, 2007 | 06:26 PM
jazdisco2002's Avatar
7th Gear
yeah check the battery. mine did the same. found out my negative cable had came loose.
Old Aug 13, 2007 | 07:36 PM
If not that, don't drive it other then getting it to the shop.
Do you have an owners manual, if so it would be a good idea to read up on your truck for future issues.
Old Aug 22, 2007 | 02:53 PM
LrTECH's Avatar
sounds like a battery to me
Chrisinhouston
Jul 1, 2020 04:39 AM
importdave
Sep 25, 2014 10:18 PM
Joe Pundzak
Feb 9, 2013 12:49 PM
Jadreigo
Sep 13, 2012 07:25 PM
vishrb
Jul 7, 2010 08:26 PM
