Sponsored by: CARiD
Slight Oil Leak
Old Nov 1, 2011 | 03:33 PM
roxiemoxie's Avatar
Default Slight Oil Leak
The car has a slight oil leak. But there is no "holes" anywhere. im puzzled about where its coming from
Old Nov 1, 2011 | 04:31 PM
atancreti's Avatar
Really? Is that all the information you can give? You should at least tell us what part of the engine it is coming from. Come on man help us out so we can help you.
Okay rant over.
Old Nov 1, 2011 | 05:36 PM
Ms. Moxie,
Rovers are famous for oil leaking, not to be alarmed if only drops and not large puddles. You can place fresh sheet of cardboard under the vehicle to see where it drips from, then the detective work begins.
Because you have an older truck with almost no miles (117 when you got it?), you may still have some gaskets that leak. They will dry out driven or parked.
One place that is good for leaks and may have missed attention is the valve covers. They use an 8 mm 12 point "necked down" 3/8 or regular 1/4 inch socket, not always in every toolbox. Routine is to snug them up every oil change.
Other than that, how is the youngest Disco in America doing?
rossmacwillson
Jun 11, 2014 07:16 AM
humroot
Jul 3, 2010 10:29 PM
drhunter
Apr 5, 2007 09:32 PM
AustinAdam
Feb 4, 2007 01:20 PM
resqguy77
Apr 30, 2006 02:53 PM
