Go Back   Land Rover Forums - Land Rover Enthusiast Forum > General Land Rover Forums > General Tech Help
Register Forgot Password?
Old 09-14-2011, 09:52 AM
Member
Default Leaking Power Steering Pump
I've located the leak and it's this seal. Is this replaceable and if so what's it called?
__________________
Spec Op Shop
Divebomb, Inc.
Old 09-14-2011, 11:01 AM
Junior Member
that looks like the power steering box, not the pump. Looking at my RAVE manual [DII], the part is called the "seal - input shaft - steering box" and a direction for replacement is given, but the part number is not listed.
Old 09-14-2011, 11:12 AM
Member
this is a 98 disco... still apply?
__________________
Spec Op Shop
Divebomb, Inc.
Old 09-14-2011, 04:50 PM
Junior Member
Yes the idea, but probably different parts. Here is what you need: OEQ Steering Gear Seal Kit
Seems as though you've gotta buy the whole kit.
Old 09-15-2011, 10:37 AM
Member
Thanks I ordered the kit.
Next on the list is another leak. There are 2 hoses one at the oil filter and the other at the pan. Anybody know what you call these?
__________________
Spec Op Shop
Divebomb, Inc.
Old 09-16-2011, 12:43 AM
wheelgarage's Avatar
Senior Member
Those are your oil cooler lines, which are simple to replace. They route from the oil filter cavity to the radiator, passenger side, attached at the top and bottom.
I ordered replacements from British Pacific. You will need to order the TOP and BOTTOM hoses.
Good luck.
__________________
1996 Discovery SE7 - 5-Speed
Fully protected by Redline Oil / Lucas Grease
Terrafirma: MED Duty Lift Kit, Steering Damper, Castor Correct Radius Arms, Rear Cranked Radius Arms, Shock Turret Rings, HD Track Rods, Extended Stainless Brake Lines
Tyler-Engineering Steering Damper brackets; Polybush Orange Kit; OEM Swaybar Bushings; Adventure Roof Rack; Hella 500's; ARB Front Bumper
265/75/16 Cooper Discoverer STT; Terrafirma 16 x 7 TF100 Alloy Wheels - Anthracite
Work in progress......
Old 09-16-2011, 12:05 PM
Member
Thanks! Ordered! Waiting with drip-pan in place.
__________________
Spec Op Shop
Divebomb, Inc.
Old 09-16-2011, 12:23 PM
Member
Next on my list is making front and back bumpers.
Saw these the other day on a Jeep. I'll be copying this design for the most part with a few changes to work better with the Disco obviously. Bumpers are crazy expensive and I can do it for a lot less $$$.
__________________
Spec Op Shop
Divebomb, Inc.
Old 09-16-2011, 12:53 PM
Senior Member
Do good bumpers and you may have found a side job that pays for the Disco parts and more...
__________________
Old 09-16-2011, 01:09 PM
Member
Well, I'll plan on doing GREAT bumpers then. Extra $$ is always welcomed. I used to weld pump housings that were used on Navy ships so I got the the welding down. It's gonna be more making a great design that works well. Also, I've been wondering about what to finish them with. The bumpers in the pics were kind of rough and seemed to have an almost bedliner finish to them.
__________________
Spec Op Shop
Divebomb, Inc.
Tags
02, buy, discovery, kit, land, leak, power, pump, range, rover, seal, shaft, steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
