Sponsored by: CARiD
Transfer case does not go out of high gear
Old Aug 5, 2012 | 10:31 PM
eitydeuce's Avatar
Default Transfer case does not go out of high gear
00 Disco that I can not get out of high gear. Any ideas? I tried going 5MPH and shifting to N but it does not come out of high gear.
Old Aug 5, 2012 | 10:39 PM
nahtanoj's Avatar
you probably need to get under it and clean and lube the linkage.
Old Aug 6, 2012 | 07:02 AM
b63215b's Avatar
Default Clean
Yes, I agree mine was the same then i got under there lubed it and cleaned and now she is good. IT happens for not being used, some make sure you use it and cycle through the gears a couple times a month.
Old Aug 6, 2012 | 07:17 AM
Common issue, you most likely have a shift solenoid on the t/case that has failed. It can be replace or taken out and not used any more.
How mechanical are you?
Old Aug 6, 2012 | 05:43 PM
eitydeuce's Avatar
That doesnt sound too bad, whats the best way to change that or where and what do i lube
gmad
May 27, 2015 12:11 AM
BIGTSV
Jul 31, 2013 05:36 PM
Illya
Jul 28, 2013 04:25 PM
Lord Wert
Mar 27, 2013 06:50 AM
Scott R
Dec 25, 2009 03:43 PM
