Reduced Engine Perf., etc.
Old May 16, 2011 | 01:48 PM
LaGirl's Avatar
Default Reduced Engine Perf., etc.
I have a 2008 LR2 that has never given me serious problems but today it starts popping up with DSC fault, reduced engine performance, transmission fault, etc. It shut down and I can't drive it. Can anyone tell me what the problem is? I have a local mechanic here that can look at it because the dealership is about an hour away.
Old May 17, 2011 | 04:54 PM
tprideout's Avatar
Default reduced engine perf
My 2008 LR2 had exactly the same problems and registered the same error messages. It was the battery, I had it jumped, tried to get it to charge, but it wouldn't hold the charge. If you are still under warranty (48k I believe) your dealer should replace it for free. Judging from what you listed, I'd say that's your issue too.
Good luck,
Tracy
Old May 18, 2011 | 08:07 AM
LaGirl's Avatar
Thanks so much! I did change out the battery but my battery light remains on. My husband said I may just need to run the vehicle a while to charge up the battery. I'm actively looking for an alternator right now. Can anybody give input? My battery light came on just a couple of minutes after I put the new battery in.
Old Jun 1, 2011 | 06:17 AM
Rovin4life's Avatar
need to pull the upper intake and replace the alternator. Sorry its a new car and parts arent aftermarket just yet.
But you might be able to go with a volvo one that is the same year with the same engine. You might save some but not much.
Athana
Nov 2, 2017 10:25 AM
achapman
Jun 25, 2013 03:40 PM
06Range
May 8, 2013 09:01 PM
Albert Frederik
LR2
Jan 17, 2011 11:07 AM
TheBelly
Nov 1, 2010 08:34 PM
