Question on LR2 Key Fob
Old Jan 21, 2012 | 01:57 PM
unseenone's Avatar
Who's the guy who has the fobs, the price seems reasonable.
Old Aug 18, 2012 | 03:03 AM
CCC's Avatar
CCC
Default Freelander 2 Remote battery change
The two remotes for my Freelander 2 were becoming unreliable. These are the rechargeable type of remote, they are sealed and when the battery is past its working life you are expected to pay for a replacement remote.
I purchased a replacement rechargeable button cell on the internet via Amazon, they are advertised as Freelander 2 remote battery.
I split open the case using a sharp craft knife. You need to be patient and make sure that you cut all around the outside. There is a joint inside that is hard to reach but it can be done, believe me.
I then removed the battery, two soldered tags. You will need to carefully remove solder to expose the holes in the PCB and insert the replacement battery and re-solder.
I glued the fob together with superglue, it worked well.
I have an image but do not know how to insert it.
kblank28
LR2
May 16, 2019 08:19 PM
Discolife
Nov 25, 2011 11:38 AM
pilsner
Apr 7, 2008 03:24 PM
semicntrldchaos
Oct 4, 2006 11:26 PM
Jay
Apr 27, 2005 03:49 PM
