LR3 TPMS and tires
Old Dec 6, 2022 | 05:41 PM
renli3d's Avatar
Default LR3 TPMS and tires
Hi guys, I'm trying to diagnose why my TPMS warning light is always on. My scanner shows the tire pressures so I know the TPMS sensors are communicating with the TPMS module. I'm wondering if perhaps my tire pressures are too low? The tires I have show a max PSI of 35 so I have them filled at 33. However, the door label says the rear tires should be 42PSI. Could this be why my TPMS light won't turn off? Unfortunately, I can't fill the tires past 35 to test lest I risk a blowout.
Old Dec 6, 2022 | 07:23 PM
DakotaTravler's Avatar
That is probably why, too low in the rears. What the heck tire you running with that low of a PSI? I would be more worried about a blowout for a tire not rated for the truck versus air pressure doing it.
Old Dec 7, 2022 | 12:14 AM
renli3d's Avatar
When i bought the lr3 it had toyo open country h/t tires. Not my preference and I look forward to swapping them out. I've never seen such a low max psi!
Old Dec 7, 2022 | 10:54 PM
Then I doubt they are XL rated for load. All the Toyo Open COUnty H/T that are XL rated are 50psi max. I would be wary of those....
Old Dec 8, 2022 | 11:22 AM
Blackngold77's Avatar
Check the spare while youre troubleshooting. It is monitored by TPMS as well and will trip the light.
map4774
Sep 11, 2021 06:55 PM
uoflcardfan77
Tires
Aug 20, 2016 12:10 PM
LR03NJ
Mar 8, 2016 10:26 AM
Eniam17
Jan 31, 2013 04:59 AM
lr3def
Jan 12, 2008 05:30 PM
