JERRY CAN AND HI LIFT MOUNT?
Old Jul 16, 2008 | 08:47 PM
04disco's Avatar
4th Gear
Default JERRY CAN AND HI LIFT MOUNT?
Does anyone know of a good way to put a jerry can and hi lift on a factory rear spare? or a factory rear bumper?
Old Jan 5, 2009 | 06:05 PM
kosho's Avatar
Default Re: Jerry can and hi lift mount?
Not without buying a swing away bumper. I installed my Jerry can inside and on the rear door. I went to Lowe's and bought two metal handles w/ 4 screws for each one and drilled them into the metal just above the rear pocket holder. I used a rachet strap to tie it down. Pretty sturdy and a clean look. Asfar as the Hi Jack I simply attached it to my cage on top of the roof. Some prople will fabricate a bracket and install it on the spare tire. Attached is a pic of what a forum member did. Hope this helped.
[IMG]local://upfiles/11499/6056EEC8187243CBAD5873041B2C4B44.jpg[/IMG]
________
starcraft replays
Old Jan 5, 2009 | 06:21 PM
Default RE: JERRY CAN AND HI LIFT MOUNT?
The factory bumper won't handle it, the spare can handle a high lift although that extra weight will with time cause the door winges to drop.
Old Jan 7, 2009 | 06:00 PM
tailchaser0527's Avatar
I made a copy of the safari gard spare tire hi-lift mount out of some steel plate and tubing. works great..
Old Jan 7, 2009 | 07:51 PM
kosho's Avatar
Do you have any pic's of how it turned out?
________
vaporizer wholesaler
Old Jan 7, 2009 | 07:53 PM
kosho's Avatar
Do you have any pic's of how it turned out? It did it twice sorry about that.
________
List of GM bellhousing patterns specifications
Old Jan 8, 2009 | 08:36 AM
I'll try and take some tonight, and get them up soon.
handsome rob
Jan 29, 2019 02:03 PM
FlyingZebra34
Nov 8, 2012 10:23 PM
Spike555
Oct 8, 2012 02:12 PM
faturbo
28
Jun 3, 2010 10:47 PM
03discoman
May 12, 2010 11:30 AM
