suspension installation
Old Feb 28, 2009 | 07:21 PM
charcoal grey's Avatar
Default suspension installation
I am about to order the OME 751/762 & HD springs for my 01 D2. I have been searching thru the forum and found a lot of dead links for any tutorials for spring replacement. Does anyone know if a link that still works?
Basically I think the only specialty tool needed is a spring comressor, correct?
Mark
Old Mar 1, 2009 | 07:46 AM
Mark, will you be running a front bumper and winch, if not, the 751 will cause the front end to be higher then the rear. If no bumper I would suggest a 779 front coil.
I can walk you thru the installation, check out the LRRF site for a good price.
Old Mar 1, 2009 | 05:15 PM
OK. I will look into the 779's instead. I did have plans to eventually install a winch bumper, but don't have the cash for that modification right now since I also need tires, water pump, hoses, O2 sensors, etc....that I will be doing at the same time as the suspension. Thanks Mike.
Old Mar 1, 2009 | 05:45 PM
If you are going for a bumper, go for the 751's and just sit a little taller till the rest of your work is done, save having to changes the coils again later.
Old Mar 27, 2009 | 07:54 PM
KarenCaren's Avatar
Hey mike. Please post the step by step suspension installation. Maybe some will benefit if you post it. Thanks in advance.
______________
If you ain't first your last!
battery charge
Old Mar 28, 2009 | 07:01 AM
I don't have one but can walk anyone thru it if needed.
rrhyne
Jul 20, 2011 05:56 PM
lipadj46
Jul 20, 2009 09:07 PM
LRDISCO
Nov 27, 2007 09:16 AM
samsly
Audio/Visual Electronics
Feb 2, 2007 10:26 PM
tetongolf
Feb 2, 2006 03:47 PM
