Go Back   Land Rover Forums - Land Rover Enthusiast Forum > General Land Rover Forums > New Member Introduction
Register Forgot Password?
Old 09-27-2011, 04:41 PM
cfp_ivan's Avatar
Junior Member
Default That new guy!!!
Hello everyone, I just purchased my 1st Land Rover, 2000 SE7 with 150+ miles. I really like all the info in this site and all the DIY threads. Thanks for sharing.
__________________
2000 Land Rover Discovery SE7 157k miles
New front Drive shaft with grease fittings
Custom Made front steel bumper and brush guard
CDL electric Shifter
New power steering pump
Replaced head gaskets
255/60/18 Toyo ST2 with LR3 wheels
Brembo rotors + Akebono ceramic brake pads
Old 09-27-2011, 08:19 PM
Senior Member
Welcome. You'll find the complete set of free download factory tech and owner's manuals at link below. In the technical area of the forum are lists of high miles service items that need to be done.
If your drive shafts have grease fittings, they need grease ech time you change oil. If no fittings, rebuild soon, write up is in tech section, takes 3 U-joints. Front prop shaft starts making a chirp sound, right before it comes apart and impales the transmission.
Watch temp gauge like a hawk. Anything over 9:00 is suspect. You do not want to overheat this engine or very, very bad things will happen. Like slipped cylinder liner, cracked block, leaking head gaskets.
Oil light comes on at 7 PSI. So you can cruise around grinding down your engine at 9 PSI and not know it. Check fluids daily for first week, then weekly from then on.
Oil change every 5000 miles, don't care what brand. Shell Rotella 15W40 is a good high cleaning oil.
Have fun, post early and often, pix are always interesting.
__________________
Old 09-30-2011, 09:09 AM
cfp_ivan's Avatar
Junior Member
Thank you for all the info. I have her parked right now while I wait for fluids and tune up parts. I have a few issues with it, The Disco had a vibration from 0 to 20 while I accelerate and then it goes away. Someone told me it could be a driveshaft or the parking brake drum. Any info would be nice. Thanks again for all your help.
__________________
Tags
forum, land, rover
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
