Wheel Bearing
Old Jan 13, 2012 | 04:16 PM
tonydiscovery's Avatar
Default Wheel Bearing
Hi to you all.
A new member to the forum hear and already have a question so this will show how good this site is lol.
I am now the happy owner of a 1996 P registered Range Rover 2.5 DT & loveing every second of driveing her BUT..........
I need to replace the drivers side FRONT WHEEL BEARING which i got with the Range Rover.
Question is.....Im of the understanding that the bearing has to be pressed in and cant be done by a weekend d.i.y mechanic like myself SO i went to get a price and the local mechanic told me that he could not give a price untill it was stripped down AS IT MAY BE A WHEEL BEARING AND HUB COMBINED
But as i said i have a wheel bearing so could it be wrong and i need to buy the wheel bearing and a hub assembly together????
All info on this matter will gladly be taken on board AND ALSO what kind of price to be looking out for.
Many thanks.
Tony.
Old Jan 13, 2012 | 09:02 PM
Rovin4life's Avatar
you can do it yourself but its a whole bearing and hub assembly.
is it loose or noisy?
Old Jan 14, 2012 | 02:25 AM
LRScott's Avatar
Take the hub and wheel bearing assembly to the mechanic. They will be able to tell you if the hub is salvageable, if so they can press a new one in. If not, then buy a new/used hub as a replacement. They will usually (almost always) come with a bearing already pressed in.
Grlica
May 1, 2013 06:13 PM
Harvard
Jun 18, 2009 07:32 PM
sdsilvere38
Sep 16, 2008 09:32 PM
Aquaholic
Jun 15, 2007 10:30 AM
btp226
Jun 21, 2006 05:35 PM
