Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Range Rover
Register Forgot Password?
Old 01-19-2012, 09:34 PM
Junior Member
Default need help diagnosing weird engine surge
I'm experiencing weird engine surge when i turn on my vehicle. I took it in for service, they said it was the master air flow. This didn't fix the problem Does anyone know what the problem might be ?
Old 01-19-2012, 09:51 PM
Senior Member
hc,
Will help to know model, year, miles, and your detailed description of the symptoms, nand if check engine light is on. And was this a dealer or an indy shop?
__________________
Old 01-19-2012, 09:59 PM
Junior Member
I'm sorry, the year of the vehicle is a 2006 range rover sport. I'm at 103889 miles. when I try to turn the car on, it takes a while to turn over and the engine light comes on. once its on the car starts surging. yes, to indy shop. He said the only thing coming up was the mass air flow. I replaced it today, but i'm still experiencing the same problem.
any help is appreciated
Old 01-19-2012, 10:13 PM
Senior Member
We don't have an 06 manual on the site, but here are some general ideas.
1. If you turn key and cranking is very slow, could be battery. If you turn key and have to hold or wiggle it to make truck begin to start could be ignition switch.
2. If truck surges, could be idle air control valve, which regulates engine at that idle speed. These can usually be cleaned with a solvent made for the purpose. If you can get the code number that would help.
__________________
Old 01-19-2012, 10:25 PM
Junior Member
Thank you so much. I'll check the code in the morning and post it.
i replaced the battery so thats out.
Old 01-20-2012, 02:35 AM
LRScott's Avatar
Senior Member
Was the MAF replaced with an OEM or aftermarket unit? The aftermarket units usually will not work. Try disconnecting your MAF, the computer will use default settings in the absence of the MAF sensor. If that takes care of the surging issue, then you have found your culprit.
__________________
A Land Rover doesn't leak! It marks its territory.
What do Jaguars and possums have in common? Both play dead at home and get killed on the road.
1996 Range Rover 4.0SE 167k Miles
1998 Jaguar XJ8 107k Miles
2003 Land Rover Discovery 114k Miles
2005 Jaguar XJR 52k Miles
Old 01-22-2012, 12:56 PM
Senior Member
try cleaning the throttle body. those tb was known to cause issues when gummed up. At the same time I believe you might be due for a rpgm of the tcm and the ecu. Had some issues on them years ago on SC but it might not be a bad idea if it hasn't been repgmed in a few years.
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
Tags
06, 1996, 2006, discovery, engine, idle, land, mass, problems, puma, range, rover, sport, surge, surges, surging
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
