Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Range Rover
Register Forgot Password?
Old 11-08-2011, 11:31 AM
Junior Member
Default poping noise when you take off
when you take off sometimes you will hear a loud poping noise only in drive any idea thanks for the help Cruz
Old 11-08-2011, 12:09 PM
Senior Member
Not when turning - so that should eliminate CVs.
Perhaps front or rear drive shaft U joints.
Perhaps cracked flex plate between tranny and flywheel - page attached for illustration, it is from a different part of the RAVE tech manuals (your copy awits download below).
__________________
Old 11-08-2011, 01:03 PM
LRScott's Avatar
Senior Member
It would help us to know the year and mileage of your rover too.
__________________
A Land Rover doesn't leak! It marks its territory.
What do Jaguars and possums have in common? Both play dead at home and get killed on the road.
1996 Range Rover 4.0SE 167k Miles
1998 Jaguar XJ8 107k Miles
2003 Land Rover Discovery 114k Miles
2005 Jaguar XJR 52k Miles
Old 11-08-2011, 03:43 PM
Junior Member
2000 range rover hse 144 thousand
Old 12-11-2011, 06:00 PM
Junior Member
I have the same issue. A mechanic said its a controller of some sort.
He said the part would run about 1100 and that was used. He didn't want to tell me to much about the issue.
It's only in drive for me and it doesn't allow me to get traction or torque.
Once I'm doing 40 mph or more it goes away. It's only if I step on the gas normal or a little harder than normal.
Tags
click, noise, part, pop, range, rover, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
