2020 Defender won't start
Old Dec 5, 2024 | 11:57 AM
LRvictim's Avatar
Exclamation 2020 Defender won't start
Hi all, 2020 Defender 110 HSE P400. During a 2,000 mile trip intermittently started getting check engine light and abs light (not always at same time). Also, occasionally had brief power hesitation like a cylinder misfire. Seemed like this was triggered by hitting serious road bumps. Finally near the end of the trip, the truck totally shut down while on a bumpy section of road and refused to restart. While trying to restart it, got the weak battery warning. Unfortunately this happened shortly after crossing the border southbound in Sonora MX. Had it towed on flatbed to my house down here. Hooked up NOCO charger and used iCarsoft LR v3.0 to read codes: initially only permanent code was PO135 O2 sensor (which makes sense given the occasional misfires). Cleared all the codes but still no start. Purchased and installed new battery and registered it with the iCarsoft. Still won't start - car turns on but when I press the brake and hit the start button it just shuts down. New codes are: PO85D-96 gearshift control module failure, and B0001-13 drivers airbag open circuit.
I'm at a loss now - is it loose wiring somewhere? Trying to avoid having it towed up to Tucson to a dealer. Thanks for any advice or help you can give!
Old Dec 5, 2024 | 12:33 PM
SilverSFR's Avatar
Make sure your new battery is fully charged. Often they are not even though they are new.
Old Dec 5, 2024 | 12:40 PM
LRvictim's Avatar
Thanks SilverSFR, I put it on my NOCO Genius 5 overnight before installing so it was fully charged
Old Dec 5, 2024 | 01:44 PM
wcc18999's Avatar
Check the hybrid battery
Old Dec 5, 2024 | 03:36 PM
LRvictim's Avatar
thanks Winching. Checked it with the scanner and it is saying MHEV battery is at 8.2% charge. Now if I only knew how to get to it and charge it ...
Old Dec 5, 2024 | 04:27 PM
wcc18999's Avatar
You will probably need a new hybrid battery. I do not believe there is a way to charge it as -I think- it is a 48 volt battery. Best to check with your dealer as a replacement might have to be coded. Maybe others who had theirs replaced can chime in. Good luck.
copysat
Sep 5, 2024 10:41 PM
jaldeborgh
May 25, 2024 04:50 PM
Jati
Mar 6, 2024 01:59 PM
SpyHop
Nov 30, 2023 07:55 PM
MTK
Jul 21, 2021 02:24 PM
