22" Contis Tire Pressure 44F 50R
Old Apr 20, 2023 | 02:13 PM
Low Country's Avatar
Originally Posted by GavinC
Just yankin' your chain mate. I'm no stranger to over thinking stuff.
*stands in aisle of Home Depot wrestling the merits of saving 8c between the purchase of two seemingly identical pipe fittings.
LOL.... I think we're related
Old Apr 21, 2023 | 05:24 AM
jadatis's Avatar
New Member
Originally Posted by Low Country
Hey all,
Door jamb on my 2023 D90 states PSI of 44 for the fronts and 50 for the rears. Seems high. Its 99% of the time just me in the Defender. Any tried and true settings for best PSI ?
Thanks
This " pigheaded Dutch selfdeclared Tirepressure specialist." registered to this forum to answer in this post. Dont have a landrover, so leave it at this introduction.
If you give me next from tires, I will make you a pressure/axleloadcapacity-list, with build in maximum reserve, but still acceptable comfort and gripp.
​​​​1. Maximum load or loadindex
2. Kind of tire to determine the maxloadpressure, but if you read AT xxx psi on sidewall, that is what I need. Yours probably C-load AT 50 psi.
3. Speedcode, to determine for wich speed the maxload is given by tiremaker.
Sizes would be nice, and from car GAWR's and GVWR, empty weight.
Carmakers use GAWR's and max technical carspeed with no reserve, for their recomended pressure. Or yust AT pressure of tires.
Then you " ONLY" have to determine the axleloads 99% accurate, the most tricky part in it all, and your responcibility. Then seach them back in my list, and use that cold pressure
gto888
Mar 23, 2023 11:44 AM
Ehloo
Mar 9, 2022 06:04 PM
sblvro
Feb 20, 2021 11:53 AM
buick215
Aug 12, 2011 09:14 PM
cpn LR
Jun 8, 2010 08:46 PM
